No Spark unless Throttle/Trigger is advanced?
Kenmo1
I have a 95 Sport Jet 120hp with the red stator and CDI upgrade. I am only getting spark if I have the throttle forward thus advancing the trigger a bit. No spark or intermittent spark in netrual position. Any thoughs?
j_martin
Re: No Spark unless Throttle/Trigger is advanced?
One possibility is the kill wire being shorted by the mechanical linkage in the controls. That can be found with an ohmmeter.
Another possibility is broken wires to the trigger, or the trigger harness shorting to ground when it is moved. Check it out without disconnecting it, and while someone is moving the throttle.
Might be able to tape it, might have to replace.
hope it helps
John
