no spark on my johnson 150
lee newman
While idling oneday my motor just shut down.<br />Doing some checking I found that no cylinders were firing. Checked kill circuit and it was good. Checked the stator and it was bad. Installed the new stator and rolled the engine over. fried the new stator. whats wrong? Been told the rectifier is bad. My book gives no check unless engine will run. HELP.
Hooty
Re: no spark on my johnson 150
Low/dead battery or faulty ground will cause the smoke to escape from rectifiers. What year engine ?<br /><br />c/6<br />Hooty
lee newman
1992 Johnson 150 FAST STRIKE. While idling motor<br />shut off. upon checking out found there was no spark to the cylinders. Kill circuit ok. Stator<br />was fried. Installed a new stator. rolled the engine over. Nothing. Found the new stator fried again. Been told the rectifier could be the problem. My book only shows a rectifier test while the engine is running. Whats the problem?
OBJ
Other than a low/near dead battery or short in the waring, as Mr. Hooty suggested, the rectifier/regulator could have failed ta' ground. This would let the stator charge go to ground. Buncha' amps going to ground unchecked. Did the stator fry fry like with goo flowing out or did it just open?
