No spark on cylinder 1 and 3! Need help please
cforgan
Just rebuilt my 1976 115 Johnson and everything went well except when I went to try to start it. I have spark only on cylinder 2 and 4 and a few times over hours of messing with it a spark or two on 1 and 3. Majority of time no spark on 1 or 3.
First thing I did was move the charge lead (orange wire) for ignition coil 1 to the spot for ignition coil 2 charge lead on the power pack. When I did this cylinder 1 sparked fine. Did the same for coil 3. Both sparked fine when changed to the other connection that was working fine. So that told me the ignition coils on cylinder 1 and 3 were working fine.
Next on the power pack I switched the timing assembly sensor leads for cylinder 2 and 4 (the working ones) with the sensors leads for cylinders 1 and 3. When I did this cylinder 1 and 3 were sparking now and 2 and 4 were not. So that told me the power pack seems to be working fine.
With this said I am thinking my sensor coil in the timing assembly for cylinder 1 and 3 is bad. I ohmed each sensor lead and got 7 ohms which is within spec but from what I have tested it seems like it could be bad.
How do check if the cylinder 1 and 3 sensor lead is bad in the timing assembly?
Does it makes since this could be the problem?
Should I check something else?
Wanted to get some feedback before jumping the gun buying a timing assembly. The timing assembly are pretty pricey.
Thanks,
Clay
emdsapmgr
You will get some excellent ignition troubleshooting info from this website: cdielectronics.com. Look for your year engine in their troubleshooting guide.
They have excellent test values for various ignition components. The cranking output voltages are very useful-but you'll need a special "peak-reading" voltmeter.
kodibass
Master Chief Petty Officer
do you have a peak voltage tester? if not you are just kinda parts replacing without really knowing what the actual problem is. it sounds to me that you may have a sensor problem but without the proper peak test its hard to say..
