No spark on 73 135hp
rodknee1231
I got this 135 from a guy did some work on the motor which was missing alot of electronics but I have 76 85hp that had cooked postings from the p.o. well I got it all back together a month ago and it ran in the driveway just fine. Go to put it in water a week later and I get some bad smoke couple coughs and that's it. Figured I fouled plugs. Took it home got it to run but it smoked bad like it wasn't firing on all 4 ran really rough too. Start checking for spark a week later with an inline tester and get nothing on all 4. This was on the same plugs but they didn't look bad so I cleaned them since the ones I ordered weren't in yet. I had a new power pack I also put in becuse I know how bad these motors can go through them but now I still have no spark. Could some fouled and cleaned plugs still cause it to not wanna fire at all ? I don't have a dva to test if it was the power pack or the pluvs. Also would a inline spark tester light up If the plug won't spark. ? I'm gonna swap stators since I have a spare but I'm afraid my timer base may be bad which I don't have laying around
emdsapmgr
On your engine, there are 4 major components in the ignition system. If you've got spark issues, you need to evaluate all 4 in order to determine just where your no-spark problem is originating from. The 4 plug coils are generally pretty reliable. For sure, it's unlikely that all 4 will go out at the same time. Swap them around for testing purposes. That leaves the timer base and the stator. You can follow the troubleshooting tips in this online guide to validate both the timer base and Stator: cdielectronics.com. You will need a special "peak-reading" voltmeter in order to test these items. If the stator, coils, and timer base all qualify, then it's likely you will need a new power pack. Be sure to validate the key switch, too. If they get water in them with age, they will act up.
rodknee1231
Can a bad key switch cause the motor to turn but not spark
The flywheel needs to spin rapidly to get spark.-------Inspect battery / battery cables / starter motor !!
rodknee1231
Battery has 12.5 volts starter seems to be cranking just fine.
emdsapmgr
A defective key switch can cause a no spark condition. You can do a test. Disconnect the control box at the engine end. (the big red plug) Jump start the starter with a set of automotive cables and a known strong battery that will crank the starter at least 250 rpm's. If you get spark, then the problem is somewhere in the control box wiring or key switch.
rodknee1231
Well it fired up today the inline spark tester I have won't light up though not sure why. I swapped the stator with my spare. However my starter will engage and then disengage before the motor starts the battery is good i know this for a fact would that be a solenoid or starter problem
emdsapmgr
Do a test. Jump the starter with a set of automotive jumper cables. If the starter cranks the flywheel at least 250 rpm's, likely the starter is good. Recheck the start solenoid. Old solenoids will burn the tips inside and won't transfer enough current to spin the starter.
rodknee1231
Ok so I put it on the water it runs good on the high end lots of power but it's kind of a rough idle. I have to use the warm up lever quite a bit and it does If I put it down all the way unless it's been running for a while is that normal? I've never owned one of these so I'm not sure. Like I said though it runs like a raped ape once you get it opened up
