No Spark on 1 and 3, 2 and 4 OK
SCFordMan
I have a condition on my 1973 Johnson 115: cylinders two and four have spark but one and three do not.
I wanted to test the 1 and 3 coils by swapping their leads in the powerpack with either #2 or #4 that was working.
I opened up the power pack and I put the #1 coil hot wire on the #4 spot and I put #4 in the #1 spot, tightening the small PP screws. I was surprised to see that both number one and number 4 both started sparking.
I then swapped the #3 coil with the #4 coil and both 3 and 4 started sparking. I was glad to see that both the #1 and #3 coils seems to work. But was surprised to see that #4 would work when tightened in the #1 or #4 spot on the PP.
I then put the #1 and #3 coils back to their rightful places on the PP and now neither will spark, just as it was when I started.
Does this point me to the stator as a problem?
GA_Boater
SCFordMan Welcome aboard.
A new thread for you after moving your post out of a 13 year old one.
Honorary Supreme Mariner
Test the stator and test the sensor coils.---Simple checks with a digital ohm meter.
SCFordMan
Ok, I have an update!
I removed the wire leads for all four sensor wires from the PowerPack. The white/black and black/white sensor wire leads for cylinders One and Three read 3.6 Million ohms across those two wires.
The white/black and black/white wires for sensors on cylinders 2 and 4 read 12 ohms across those two wires. All four leads read infinite to ground.
The PowerPack leads on terminals 7 and 8 (I think the charge coils) reads 652 thousand ohms.
Thinking there's a break in the sensor coils for cylinders 1 and 3?
If so, I'm wondering why the #4 spark plug will fire when screwed into the #1 or #3 terminal in the PowerPack.
3.6 million ohms ??------And 652 thousand ohms ??-----Check your readings and or scales on your meter.
SCFordMan
Yes, sorry about that, it's actually .652K, so 652 Ohms for terminals 7 and 8. But 1 and 3 it's showing 3.6 Million which I think means infinite. I tried the sensors again for cylinders 2 and 4 and now it looks closer to 9.2 ohms, my digital meter was dancing around a while but seems to have settled on 9.2 ohms for those sensor wires.
F_R
Simple. One of the sensors and associated wires fires #1 and 3, Other sensor & wires fires #2 and 4. So you have a bad sensor or busted wire. Don't make it complicated.
EDIT: Um, I see that the sensors are only sold as part of the timer base $$$$ With any luck, it is just a busted wire that you can fix. Cross fingers and hope.
SCFordMan
Think I should remove the flywheel and see if I can find a busted wire?
SCFordMan
Ok, so I removed the flywheel, the stator and the timing base with the timing sensors. Took the timing base off the motor and verified on my bench that the 1X3 sensor had no conductivity. I could also see the black goo of death dripping from the innerds as well.
I saw that a new timing base is kinda pricey - $300-$450. So I had a look around and saw a very similar looking sensor, part number 581414, for $25. So I ordered that and I'm going to see whether it fits / works in the original timing base.
Where did you order it from ?----What was the description of this part #
SCFordMan
I found this on eBay, part number 581414, I wasn't able to confirm that it fits the 1973 model, but looks exactly like what I removed.
OMC JOHNSON EVINRUDE 581414 OMC Sensor & Shield Assy NEW NOS
