No Spark- Force 125
danvandyke
I just bought a 89 bayliner with an outboard Force 125 motor. Only one of<br />the four plugs spark when turning it over. Its not the plugs. On the<br />passenger side of the motor there are a number of wires which attach on a<br />strip. 2 wires (not coming from the stator/trigger area) are loose and<br />appear they should be attached to the strip, however i attached them to<br />different spots on the strip with no resolve. one i believe is white with a<br />yellow stripe - other is white with w green stripe. Any change you have a<br />wiring diagram on this motor? I used a volt meter throughout the length of<br />the strip and when I turned over the motor there was voltage at every<br />location.
