I've started a new thread because i've done so much work and things have changed so much.
Boat ran great last year, but still haven't got it running this year and season getting close to over!!
Boat details, 1996 thunderbolt 180 with 3.0 mercruiser, alpha one outdrive and electronic ignition.
Boat turns over but has no spark at the coil. Starter was seized up so it has a brand new starter. it needed a tune up anyway so i put a brand new coil, distributor cap and rotor button, spark plugs, and wires. slave solenoid is not new but test good with test light. only thing left is the ignition module, but i dont know how to test that.
i let someone convince me the it was a mechanical which is one reason why i replaced all that stuff. i was originally thinking the problem was in the kill system and starting to think that may have been right. i have bypassed the lanyard kill switch, tried to jump the motor using wire between to big terminals on slave solenoid still nothing!! i am about to run out of ideas!!!
any suggestions would greatly be appreciated!!
