No spark at all on 04 75 hp merc
Tommyorrison
i have tried everything. Motor was running great than died. Started 2 more times for seconds now have no spark. All items coil packs plugs and wires stator trigger with two cps timing key switch rectifier /regulator battery compression 150 on all 4 cylinders. Fuel pump is good all carbs have fuel just cannot get spark. Tried another cdi off friends boat. Nothing. Pleaseeeeeee help
Tommyorrison
Update. Boat is fixed. After all ignition checked out it ended up being the red wire on the middle ecm connector had o volts but up top it had 13 volts the wire broke inside the jacket at 1 inch out of connector in a bend. No corrosion no melted wire nothing. Repaired wire and started instantly. Factory defect. Yamaha part of my mercury wire harness
