Re: no spark 74 johnson 115 hp
Gwatt.... What you would be looking for pertaining to the stator is a cracking and oozing of a substance at the forward and rear portion of the stator. That is where the two large coils are located that supply 300v AC to the powerpack. The faulty area(s) may not be visible without lifting the stator to view the underside.<br /><br />If the stator appears to be perfect in appearance, with a ohm meter set to high ohms, connect the meter leads between the stator BROWN and BROWN/YELLOW leads. The proper reading would be 630 ohms +/- 75 ohms.<br /><br />Then connect the meter BLACK lead to a ground, connecting the meter RED lead to the BROWN and then to the BROWN/YELLOW stator lead. There shoulld be absolutely no reading at all. Any reading would indicate a short within the stator.<br /><br />If the stator checks out okay, remove the black/yellow wire from the powerpack and check the spark again. If you now have spark, there is a short in that wire within the engine wiring harness.<br /><br />NOTE... Be sure to torque the flywheel nut to exactly 105 foot pounds when you replace the flywheel.
