No Spark #2
CapTWilly1127
I have the same symptom. I have no fire on cylinder 2. If i move the wire from the power pack to another ignition coil the problem follows.. . then #2 cylinder will fire and spark (tells me the ignition coil is good)
Appears i have a bad power pack. Getting ready to replace the power pack next.
GA_Boater
CapTWilly1127 This is your thread moved out of an old thread.
People will be asking some questions, like what motor? This was moved out a thread about a 70HP J/E.
gm280
Well it sounds like you already located the problem and ordered the fix... Seems like a good plan to me!
GA_Boater
Please don't post in old threads. That's why this thread was started for you and two more 10+ year old threads are now closed.
Answer the questions we've asked. It's the only way we can help you. What are you working on?
