Hello everyone, this is my first post here. I've been lurking around for awhile now soaking up all the fantastic information in the forums.
Anyway I recently bought my fist boat, an old 1970's runabout and I've been slowly restoring it and getting it ready for the water. I came across a bit of an issue with the bilge pump today.
I opened up the floor (was rock solid) and installed an access hatch ready to put in a pump next week, at least that was the plan. That went well, the hatch is in, the problem is there's only about 4" or 10cm clearance between the bottom of the boat and the deck. My understanding of the safety rules here in Victoria (Australia) is that I'm required to have a bilge pump by law in any boat that has a floor, so what are my options here?
Should I shop around for a low profile pump that will fit in that tinny space or should I cut another hole in the deck and build a box up around it above the floor to house the pump? Manual pump maybe?
Here is a quote of the regulations regarding bilge pumps
There's some pictures at shareaproject.com (see link bellow) I haven't had the chance to add any of the bilge yet, but at the deepest point the is about 4" or 10cm slopping down to about 2" or 5cm I can only just fit my hand in there!
http://www.shareaproject.com/pages/projectTut,p,544,00.html
Thanks in advance for any suggestions.
Am I misunderstanding this regulation? In any case I really do want a bilge pumping system of some sort in there.Electric or manual bilge pumping system
(if vessel has covered bilge or closed underfloor compartments)
