FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
mmmmmm thats a tough ? i dont put it in reverse very often, i went fishing the other day, and needed it, the lever will only go as far as in neutral. forward is fine,
thanks
Well, if you have the shift handle on the side you can check to see that it has not come loose.
You can pull the water inlet screens and gain access to the shift rod and manually shift the rod to see if you can engage reverse. Do this with motor off while spinning prop by hand.
Drain the lower unit and see if you get metal and/or water out.
