'66 Merc 100... PreAlpha Model 60
After reading everything I could find in this forum and following all previously stated suggestions, checks, measurements, and assistance given to others, I have found that the shift shaft of the lower unit had fallen down enough to disengage from the upper unit shift stirrup. Everything I read says I am ahead to remove the complete outdrive before removal of the lower unit, but I can not find anything that explains why...
Question: Can you tell me what the fight will be when trying to either remove or re-install the lower unit 'without' removing the complete stern drive?
