No Reverse
cjwheel
Hi, just got done rebuilding the carb,fuel pump and primer assembly on my 2000 Mercury 25 HP tiller.I noticed the timing link was sticking so I removed the throttle cam control lever and lubricated the bushing and put back together. Everything looked good but now I cant get it to go into reverse.Everything works fine in forward however when you twist the throttle in reverse it just stops. What did I do wrong?
2000 mercury 25 HP serial # 0G983335 Any help would be appreciated
