No reverse Last Night now oil from prop.(96\ 48hp). Help
marcusrav
Out and about last night at my favorite fishing spot. Launched fine reverse worked. Started her to come back found I had no reverse. This morning thick oil from prop. How bad is it doctor I can handle the truth?
ob
Re: No reverse Last Night now oil from prop.(96\ 48hp). Help
Sounds like a failed propshaft seal or carrier "o" ring.Remove the prop and see if you picked up some fishing line that intruded the seal.Then remove the drain and vent screw on the lower unit and tell us what you find.Water ,metal shavings?
marcusrav
Lower unit oil looks good (not milky, no shavings). Removed prop and found nothing just thick black oil that looks nothing like lower unit oil.
ob
Probably just two cycle exhaust oil residue.Good indicator of an engine that is a candidate for a decarb procedure.You can check out decarbonization topic in the FAQ section for some good info on the subject.<br /><br />As to the not going into reverse issue ,the gearcase is either in need of some attention or it is shift linkage related.Assuming someone hasn't fiddled with the shift cable trunion and got it out of adjustment,try disconnecting the cable link from the shift arm ,and attempt shifting manually by just using the shift arm.If it shifts fine out of water,that doesn't mean that it won't slip under load in water.Many times,through gradual shifting practices(instead of a brisk shift) the gear lobes get worn to a point that under load they will no longer stay engaged.Don't know if this is your issue as I'd neeed a more detailed description of the not going into reverse symptom.<br /><br />Also this shifting problem could be something as simple as a spent cable that needs replacing or something loose in the throttle controls,but try the above test and tell us what you find.<br /><br />( You'll need to spin the prop while attempting to shift manually while the engine is NOT runnning.)
marcusrav
You were right. I was missing a screw that passed through the shift rod that goes down to the lower unit (it was missing when i bought it and used a screw with lock washer till now). It is under the power head, I am sure you know what i am talking about. Thanks for your help. The screw is on order (part number 322486 if i remember correctly). I scooped up some of that oil and smelled it and to me it had no odor, so i took it to the expert smeller in my house (the wife) and she immediately said it smelled like gas. (sigh of relief). I will check out the decarbonization topic. Thanks again.
D
DJ
Guest
marcusrav,<br /><br />Here's the decarb post.
