no power
THEBOATLADY
fireing on all 6 cylinder but no power.put hand on three carbs and the motor boggs down.<br />but put your hand on the other three and it dos nothing. but when you run the motor hard you see gas in all 6 carbs.<br /><br />p.s all 6 cylinder have at lest 105 psi <br />it is a 1996 johnson 225 ocean runner.<br />please help if you can i will try anything<br />thanks a lot<br /> :confused:
Hooty
Re: no power
This is at least your third post on the same subject. It makes it real difficult to help if we don't know what has already been tried. Did you disconnect the shift switch like I suggested? If so what was the results?<br /><br />Hooty
26sabre
Re: no power
I'm not a boat pro (recently dunked my father in-laws 15hp in the ocean for 20 min, what brought me here) but I do know my way around cars. Newer electronic engines employ what is called a "coil pack" that sends spark to the plugs directly rather than through a distributor. Often times, on 6cyl engines, one coil pack will spark 3 cyl, while another sparks the other three. Sounds like this may be the case with yours. Follow the spark plug wires of the three cyls that are not firing ( the ones in which you can cover the carburator with your hand and nothing happpens, these are not firing) back and see if they all attach to (basicly) the same electronic component. Chances are that if they do, this is your "bad" coil pack. I'm sure a repair shop can test for you if you remove it and take it in, as well as supply you with new if bad.<br />Good Day :D
Hooty
Re: no power
The shift switch I suggested she disconnect shorts out three cylinders when shifting gears. If the switch is defective or not adjusted properly, the three cylinders will stay shorted. It's a pretty common problem and easy to fix.<br /><br />Hooty
26sabre
Re: no power
Thanks Hooty, my outboard knowledge gets bigger and bigger as I cruise this site. What a great place.<br /> :eek:
THEBOATLADY
Re: no power
:( hi all thanks for helping me. yes hooty i did that<br />and still the same number 4&5 running all the time . but 3&6 at no time will thay put your hand on it.<br />number 1 if you are running it will bog real bad<br />if you put your hand over the carburetor.<br />number 2 you can put yor hand over it and ther is no differents at allwhen you idle or when you are running. and last but not lest
THEBOATLADY
Re: no power
hooty is it the shift switch under the hood <br />or the one in the contols<br /> :D
THEBOATLADY
Re: no power
hi all can anyone tell me where is the shift switch is it under the hood <br />or the one in the contols. p.s thank you :confused:
whitey74
Re: no power
I think the shift switch he refers to is under the hood on the starboard side down near the bottom. It should have two wires (black I think) running to it from the power pack. When you shift it rotates a few degrees and the button on top gets pushed in killing spark momentarily to one side to make it easier to shift.
