No power to ignition switch
tarpologist
Have 1986 bass tracker pontoon, last time tried to start it turned over then acted as if batter dead, changed to new (tested) battery and still nothing,
have put meter on wires hooked up to battery and it has 12 volts, has 12 volts on boat side of fuse, has 12 volts on motor but has less then 003 on hot wire coming
into back of switch. Any suggestions?
foodfisher
Re: No power to ignition switch
A break somewhere along the wire. Likely culprit, inline connection.
Silvertip
Honorary Supreme Mariner
Disconnect and reconnect the main harness plug (the big one) at the engine. While you have it disconnected check the terminals for signs of corrosion. Clean as required.
