No power on my 75 hp Johnson
mgolding
PLEASE HELP!!!!!!! I have 1965 Johnson 75 hp Sea horse outboard (V4AL-17S). My top speed is 10mph. new gas, I have changed the plugs, checked the reed values, rebuilt the carb, cleaned and verified the gap on the points, checked to ensure fuel and spark were at each cylinder, compression tested each cylinder all cylinders read the same (90psi), and replaced the inline fuel filter in the fuel pump. However, when the engine is idling it runs fine when we pull the plug wire from each cylinder no 1 and 2 have no noticeable difference in how the engine runs but when we pull the plug wires from cylinders no 3 and 4 there is a major difference. We are at our wits end ..... PLEASE HELP
