woodsmithie
Thread starter- Joined
- Oct 18, 2008
- 8
1977 evinrude, 85hp... the continuing saga...
Test drive results.... the engine works fine in forward.... no hesitation, lag or rought spots.
When I go into reverse it seems to shift OK, but there is no power to stop forward movement.... as I move it further into reverse the engine revs up OK.
I did have the lower unit of to replace the water pump, but i did not turn the shift linkage at all.
The input cable seems to be rigger correct to the linkage....
How about an idea....
