Timothyk86g
Thread starter- Joined
- Jun 16, 2021
- 20
Hi All, after a few hours of boating yesterday, I shut off my boat on the water. Sat for about an hour. Only to realize the whole boat was dead after trying to turn it back on. No power to any of my dash components. Ignition was dead but my bilge pump, depth finder, horn, and other accessories run without the ignition being on and they were also dead. The only thing that did work was my trim motor control. So I know the battery and battery shut off switch are working. All fuses were good. I'm thinking that maybe it's a grounding issue of the fuse board, and maybe the trim doesn't get power from the main fuse boat under the dash.
I'm going to head out there with a multimeter after work today and try to narrow down the problem. But if there are any recommendations on where to start, that would be greatly appreciated. Also one quick question. There seems to be a cluster of wires under the dash that go into the hull of the boat. Is it possible to get at this wiring harness? Or if there is a problem with that harness, are you basically SOL and needing to run a new harness?
Thank you!
Thank you!
