Hi, I recently timed my 1971 Chrysler 105 using Frank Acampora's video. Since then I seem to not get any movement from the tower when using the warm up neutral knob.
There seems to be a bit of slip in the mount that holds the throttle cable and the tower. The cable has to rotate slightly before it catches and moves the rest of the tower. However in neutral that hits the blocker attached to the shifting rod before it can move the tower to open up the carbs.
I must have done something wrong, but I can't figure out what... Any suggestions would be greatly appreciated.
