no intake
lam412
I have a 1997 merc 60hp tracker with 90# compression in all 3 cylinders but no intake in no.3 cyl Why? Any help appreciated.
Faztbullet
If the cylinder is not pulling fuel you have either a carb or reed problem.....
Silvertip
How did you check the carb??. Did you try spraying a fuel/oil mix into that carb?
lam412
When running and I put my hand over all carbs it chocked, but # 3 no intake.
What happened when you had the motor running last ?----Was this a sudden failure at full throttle ?----Have you looked for a hole in the block ?
lam412
actually yes but i backed off and it ran at half throttle then quit. I got it running at home but it popped and backfired. I went through the carbs, checked the reeds they are like new even switched them around. then realized there was no intake on #3. all three cylinders have 90# compression. Im stumped!
Chinewalker
Maybe bottom seal blew out. Crankcase pressure and vacuum are needed to draw fuel. If the bottom crankshaft seal tears or rots out, it won't draw fuel.
No , because each cylinder has it own crankcase and is seperated from the others !
lam412
OK. I have the engine at the point I'm looking at the crank shaft. Would I be able to see the seals?
Chinewalker
The lower main seal would be in the bottom end cap. Not visible from the reed plate area... Make sure you exhaust all other options before digging in, as you'd need to pull the powerhead to get to it.
Chinewalker
With the carbs off and the reed plates in place, spin the motor over and see if the reeds in the bottom cylinder actually move. They will vibrate with each piston stroke. If they don't move at all, or if you can't hear air moving in there, it's likely the seal is shot.
Chinewalker
If you meant where can you find it in the motor, it is in the lower bearing cap at the base of the crankshaft.
If you meant, where can you find one to purchase, likely get it at a Mercury dealer, or any of the various online sources that deal in OEM parts.
lam412
i'm pulling the powerhead and i have disconnected all lines,fuel,elec.,linkage,etc. i also pulled the six large mounting bolts. Do i have to disconnect anything else?
