Hello. I am having trouble getting my boat to run. I have no spark or fuel present when cranking.
I have done the following:
Replace the distributor Module
Changed out the Oil pressure sensor
Changed the Oil Pressure switch
ECM fuses are good
switched out the ignition relay
Alarm comes on when key is switched on
Kill switch seems to be working (no alarm when switched off and key turned to run)
Slave soleniod turns the started motor on when jumped
Wire harness connection's look good with no corrosion or moisture
When the key is switched to run I do not have voltage to the ECM
There's a voltage drop at the input wires to the coil fr0m 12.5V to 10.8V
I can hear the fuel pump priming when the key is turned to run position
The engine and boat are 1998
OL049621 SIN
Any ideas would be appreciated, Thanks in advance.
Derry
ECM fuses are good
OL049621 SIN
Derry
