I have a 1992 40 hp Johnson its on a pontoon the problem is only 1800 rpm's in forward gear when boat is tied to dock, about 2200 rpms wide open throttle moving. The motor operates fine on the trailer with flush attachment. This motor works fine in reverse. What i have eliminated so far is linkage,spark,fuel,plugs, and rectifier. Someone told me the prop hub might be spun. Any help or ideas will be helpful. thanks RICH
