no guts and power
reidsmith
i have a chapparal 1930ss 1994 with a mercruiser 5.0. i have not used boat in 3 years and gas has been in there the whole time. it idles fine oil pressure and temp are fine, but it takes forever to get out of the hole and only tachs at 3100 rpms. normally will tach out at 4800 rpms. need to know if its a gas problem or something else i should be looking at. also had complete tune up this spring. any help would be great!!!!!
airman
Re: no guts and power
Change your gas before you try anything else. It's slow, but you can simply disconnect the fuel line and pump it out with the primer bulb. If that solves your problem, add the gas back a gallon or two at a time with lots of fresh gas and pretend you're only paying $1.05/gal for a while.
airman
You can, but bad fuel can make a bit of a mess of the fuel system too. Really you should throw it out if it's got any water or junk in it but it can be hard to find a place to take it. That's why I usually just look at it to make sure it's clean and then mix it back in. Change the fuel filter when you're done.
tylerin
Reidsmith, I thought you were trying to find out why your 5.0 only tachs at 3100 rpms. Bad gas usually smells differant. If you think its bad gas, I would syphon gas out, fill it back up, add omc 2+ 4 gas conditioner (follow directions on can) change fuel filter and water seperator filter and give her a try. Just a suggestion
3 Years ???!!!!!!<br />Of Course it's Bad Gas......<br />As stated above... Pump it Dry, Refill with fresh gas,+ Change your filters.....<br />You just Might get Lucky with the carb....
chris in va
Yup, bad gas. The boat I bought over the winter had been sitting for several months, and it ran like crap until the old stuff was burned off.
