No ground
Sippin & slidin
Help.. Recently took boat out, after about 30 minutes of running it died.. Lost all power to front of boat.. Ign. Stereo, exc... Discover main plug behind motor had came unplugged .. Now boat turns over but will not start.. Have power to everything, but no ground...removed ground from battery terminal And have tested from positive side of battery to everywhere I can think of on motor .. With no results
Re: No ground
Ayuh,.... The Other end of That wire,... Grounds the Motor....
achris
More fish than mountain goat
Re: No ground
So, the meter is giving you the right results... If you disconnect the negative cable... Of course you're not going to show any voltage between battery positive and engine block, The circuit is incomplete!... :facepalm:
Sippin & slidin
Re: No ground
K,, wasent thinking, stupid moment!! Getting power to purple wire on ignition coil with key on ( 12v ), but no spark??
Don S
Re: No ground
Are you cranking the engine over when checking for spark? Is the lanyard safety switch hooked up?
One other small detail, what engine are we working on here? Engine serial number would be a good thing.
Sippin & slidin
Re: No ground
Yes engine is being cranked over.. Not sure On the saftey switch
Just looked and one of the red wires is running to the back
The other is hanging with a wire nut but not connected to anything??
Not seeing any wire to hook it up to.. Would the engine still crank??
Oh ya the boat is a 94 celiberty with a 4.3 merc..
Thanks for your help
Sippin & slidin
Re: No ground
k,, Just checked and red wire hanging from saftey switch has 12v .. But not hooked to anysthing ??
Ignition swith had 12v to red wire and is recieving to volts to red/yellow wire when turning over
achris
Re: No ground
And what of the purple wire on the back of the ignition switch?
Sippin & slidin
Re: No ground
k. ignition switch is wired as follows
B - Red
A - Pink
l - Purple & Purple/Red When I try jumping the red wire from the lanyard switch buzzer sound then after about
30 seconds loud alarm sounds ??
S - Yellow/Red
Sippin & slidin
Re: No ground
Update.. Boat running like a champ..
It was the shift interrupter switch..
Although the switch is no longer available
The plate kit was an easy install
