no fuel
akelley
newbie<br /><br />after running my 94 sea rayder w/sportjet 90, for 15-30 min it shuts down. no fuel gets to the sparkplugs. fuel does get to the carbs
akelley
Re: no fuel
thanks.<br />the tank is vented. could this be a powerpack problem. it seems to shut down after the engine gets warm.it starts right back up after 3 or 4 hours. when it shuts down, i have spark at plugs, and have fuel pumping to the carbs. after shutdown, when trying to crank sparkplugs are dry with carbon buildup.cranking with plug out only air comes out of cylinder
roscoe
Re: no fuel
If you have spark at the plugs after it shuts down, then powerpack is ok.<br /><br />You might try asking this over on the Mercury forum page.
