Alright folks,
first post. This place has a wealth of knowledge. Just bought a boat with a slightly used engine. It was blowing oil filter seals... no big deal. Pulled the engine, repaired the pump, validated all was working correctly, yada yada yada....tested the OE fuel pump - it was no good. Bought an auxiliary Holley fuel pump (4-7psi)... installed it, pumped great, i think... injectors were terrible. Tried cleaning those with no luck, ran 1.5 hrs away to get injectors for a "1992 chevy 4.3" (year and model of "vehicle was irrelevant. I think??) Installed new injectors and they sprayed wonderfully...i guess?
a couple questions..
what psi auxiliary fuel pump should i run?
is there a difference in injectors between marine and automotive?
injector part number is a BWD # 57202P came from O'Reilly's. Is this the same as a marine injector for this engine? Why or why not?
The engine cranked and started but i had to continuously hammer throttle and back off, hammer throttle and back off...it was obviously just reving, wanting to die, rev up so on..... any thoughts? I DID leave OE fuel pump in there in case that has anything to do with volume/rate restrictions
engine S/N is OL347511
i have spent hours upon hours going through this thing to get my mother on the water and unfortunately, i was not able to succeed.
please help!!!! Thanks in advance!
