No fuel going into second cylinder
blakevw
Looks like I have diagnosed the issue down to no fuel getting into the second cylinder. does anyone have advice on how I can clean the carb without removing it?
DavidMoore
My advise on cleaning the carb without removing it - you can't so don't waste your time trying.
+ I'm guessing you have more than one, so if your doing one, why not do them all.
Take them off, strip ?m, clean ?m thoroughly, put it all back together, do a link and synch. You will be rewarded for the effort.
blakevw
thanks guys, took them off, found sand around the pin. it was clean otherwise.
