drive serial #ok223391
Hi I have a bravo 3 with a issue with forward gear. I was at the dock and put it into forward and .... nothing happened reverse works just fine.
I pulled it out of the water, checked the cable and it was connected and moved just fine. went home put it on the muffs and manually shifted the cable. still just reverse.
Next I pulled the drive and started to look for problems there. The cable coming into the drive moves freely.
Is there anything else that may cause this problem before I spend the quoted 1600 on a clutch assay.
The symptoms prior to this were that it would not come out of drive easily after a long run and going into forward gear there seemed to be a little hesitation like a 3 count before it would actually engage or you had to bump the throttle a little to get it to engage - ie just before the engine would start to advance.
Any suggestions are very welcome!
Thanks
mike
Thanks
mike
