No Fire
debuc
1984 75 hp Mercury
Motor has been setting for 3 years outside. Wiring on stator , trigger, and wires for coils to switch box bad. Replaced these components. New Switchbox. Have replacedc rectifier tested bad. Tried internal wiring harness off of a working motor. even replaced ignition switch still no fire. Any ideas.
Charlie61
Re: No Fire
Are you saying your not mgetting a spark or motor is not starting. 1= remove kill switch in motor it there is one .2= if not starting check gas need new gas only.
debuc
Re: No Fire
Not firing and have already tried removing kill switch.
