No Fire with my DDIS System
joshua2101
I am officially stumped and beg for help.
The problem is this: When the key is in the run position I get a back fire or fire at the plug and during cranking I get nothing what so ever and another backfire after cranking when i hit the run position.
Here is what i have tried.
1. Test the digital coil pack for resistance
test motion sensor and it was good
test ignition module and it was good
tested the interrupter switch to be good
New plugs
New battery
New wires
jumped key switch to be sure it wasn't that
PLEASE SOMEONE TELL ME THEY HAVE HAD THIS HAPPEN AND HAS A CURE.
ps: 1989 Chaparral 178 bowrider
Don S
Re: No Fire with my DDIS System
You do understand that none of the parts for that ignition system are available anymore don't you?
Are you checking things per the OEM service manual? (Not Clymers or Seloc)
joshua2101
No i didn't know that but that's not good to know....... but any testing info has come from my mercruiser service manual.
JustJason
If it's not as simple as a lanyard or a short in the system someplace, start looking into the Delco Voyager replacement ignition systems.
joshua2101
Thanks for the reply's and i do understand that replacement may be necessary but it was running a couple days ago and then nothing.
I was hoping that someone may have encountered this before and found a fix for it, or at least may think off something I haven't.
Thanks guys.
PS: Great forum
Don S
joshua2101
Thanks.........looks like a good route.
