no fire starboard bank
kwt600
Hey guys. I have a 02 Johnson 150 ocean pro. It has been cutting out what looks like the entire starboard bank once warmed up. Was thinking coil by the way it acted until I seen the plugs and all 3 starboard were oil covered and port side looked normal. Any help is greatly appreciated.
Thanks, Ryan's
Re: no fire starboard bank
Need a model number. start with spark and compression. tons of posts on here about how to do those. The plugs that look normal may be the ones not firing and may be gas washed. Or the starboard bank could be running rich.
I recommend you test for spark with a timing light. If you find a no-spark condition, the two likely suspects are the SLOW (overheat function) and the shift assist switch. Both kill spark to 1/2 of the motor.
kwt600
ok did spark test it is not the starboard side. actually the port side with no spark. disconnected the switch as per manual and spark did not return. now im waiting on my dva adapter to get here to test stator. if anyone has any other reccomendations im open to hear them
boobie
Get your dva adapter and keep on goining. Then post back here.
You might disconnect temp sensor wires and see if spark returns. You will need to make sure the motor doesn't overheat in some other fahion, since you disconnected the warning system.
hidef
There are a couple of other tests you can do without the DVA check out page 62 in the CDI troubleshooting guide. The link to the guide is in my sig.
kwt600
Well I couldn't wait on the meter. Had a hunch and a spare pack. Switched it out and now I have spark. Motor ran smooth on muffs after I put it all back together hopefully this fixes the prop. Thanks for the help
kwt600
Quick question. Do you guys think now that I have my dva adapter. Should I go ahead and test everything or not worry about it since I have my spark back
