No Fire any cylinder
Crappie Reaper
'84, Johnson V-6 GT vro with vro bypassed.
No fire to any spark plug. Motor has sat since '06, cold compression 98-99 lbs on all 6 cylinders.
I picked up an '84 Ranger 373v that was in dire need of TLC. Previous Owner stated Motor was good other than the lower unit which I have replaced. I rebuilt the guts of the Ranger including removing all gauges (marking what color wire went where), rebuilt the console with newer rocker style switches along with doing the same for the front panel at bow of boat.
I also installed a newer ignition switch in the remote that was on the remote I got when I bought the used motor for the good lower unit.
I'm not sure where to start testing to see why I am not getting fire to the cylinders. I have checked the purple wire under the console. No power when ignition switch is off, and only about 6-7 volts when ignition switch is on. I've also looked for the black/yellow stop wires to check the stop circuit and cannot locate them. The starter cranks the motor over just fine with plenty of RPMs when battery is fully charged.
I'm not sure if I have messed something up when putting the console gauges back together or if there was something done before I took possession of the boat as the front panel electrical was pulled out and several things cut or disconnected. I do know that the tilt/trim on the stern and console operates backwards (up is down and down is up). Another thing, the 7 colored and numbered bus terminal on the Starboard side of the engine for some reason gives me a negative 12 volt reading while using a meter, (black to grnd and red to each different connector on the bus).
Is there a way I can bypass the ignition switch to power the motor other than the starter? Like I said, ignition switch turns the motor over just fine.
This motor was last tagged in 2,005 and has set outside until I aired the tires up and parked it in my shop. There were numerous mud dabber nexts under the cowling on the block and even into a couple of the carbs which have been taken apart and cleaned.
Both fuel tanks were pulled, cleaned and fuel lines were replaced as well.
Any guidance would certainly be appreciated!
emdsapmgr
Compression is normal for that engine. Generally, the engine is wired separate from the boat-at least today it is. All the boat wiring and gauges, etc are usually wired direct to the start battery. So is the engine. The engine has it's own wiring harness connected between the control box and the main wire harness under the cowl. So, separate your boat issues from the engine issues. That engine has to crank at least 250 rpm's in order for the electrical system to fire the ignition. So, check the battery and starter.. Since you have no fire/spark at all, you will need to validate the stator and timer base from a voltage output standpoint. You can test for voltages from both devices when the engine is cranked. You may find this website handy for ignition troubleshooting info: cdielectronics.com They have some pretty good stuff. If both of these devices check out ok, then you will probably want to replace the power pack. All 6 coils just don't quit at once. Likely they are not the problem. All of these devices are expensive, so a little testing on your part will be worth your time.
Crappie Reaper
Thanks for chiming in emdsapmgr, I realize all coils are not going to go bad at once. That's why I've been looking at power from ignition switch. From what I can figure, Battery to remote control, remote control to motor, then from motor to console. I know the battery and starter are great and good to go. I've been looking at the 6 cylinder Johnsons in a pdf file from CDI. http://www.ebasicpower.com/downloads/cditech/CDI-Troubleshooting_Guide-JOHNSON-EVINRUDE.pdf (Admins, if this link breaks rules please remove)
So I guess I need to learn how to validate the stator and timer base as you said. Any idea where I could find a breakdown of these things so someone like me can figure out how to do it? I'm self taught on most items and the tests you suggest are new to me.
Thanks!
sutor623
You sure have the right idea to use the CDI troubleshooting guide. Get (or build) yourself a DVA meter and you will be all set.
