No fast idle/throttle cable adjustment
NYBo
I have discovered that the fast idle setting doesn't move the throttle on the motor. Without bypassing the shifter, the throttle doesn't start to move until the throttle is pushed almost 90* from the neutral position. I wasn't able to attempt to go to WOT on the water the other day due to the roughness of the water. I'm wondering if this means the throttle cable isn't adjusted properly. Thoughts?
foodfisher
Re: No fast idle/throttle cable adjustment
Fast idle won't let you go wot. Not sure what you're trying to do?
NYBo
Using fast idle (OE U.S Marine controller box, pull throttle handle out, push forward) did not move the throttle cable at all on the motor. In regular mode (motor off), the throttle cable did not move on the motor until the throttle handle was most of the way forward. I'm looking for the procedure to make the initial setting of the throttle cable. This is not the original motor and I just clamped the cables in the same position as they were on the original after I did the swap.
Frank Acampora
IF the throttle cable quick-connect is attached correctly, the spring loaded center slug will be pulled out about 1/4 inch in neutral. During operation, this PREVENTS the throttles from opening until the engine is fully in gear.
IN neutral with the shift locked out, this will also let the control handle move a good bit before the carbs start to open. This is normal. To some degree, you can adjust the amount the control handle moves by adjusting the amount of spring loading By threading on or off the control cable. More loading (screwed further ON the cable) will let the handle move more and less will let it move less until you get to the point where throttles start advancing at the same time as shift starts to move--This is not the best situation.
The neutral interlock tabs prevent the engine from over-revving in neutral. They only allow the carb butterflies to crack open and timing to advance a couple of degrees. HOWEVER: If the idle stop screw (for whatever reason) Is screwed in too far, then most or all of the travel will already be used and in neutral you may not be able to rev the engine at all. The cure for this is to sync the carbs and timing and to set idle correctly. (watch the video and read the sticky) IF after synching, you can not set idle without screwing the stop screw too far in, then the engine is sick. Do a compression test and check fuel delivery and ignition systems.
If the control handle moves too far for your comfort, then try a different hole in the lever inside the control box, assuming a US Marine box. Chrysler control boxes only have one hole, there is no adjustment.
NYBo
Thanks, guys. I think I have enough to go on. The motor starts very quickly even without fast idle and doesn't stall.
