Re: No compression
Your probably wright about taking the block to a machine shop but i don't want to put much money in this it is 33yrs old. I put 2 of the diverters in between the middle cylinders there were obvious spots for them. The other 2 i put 1 on each end as they would not fit tight any where else. When i took it apart there was only 2 in there 1 on the end by cylinder 5 and 1 in the middle and both were like melted. I figure i will try the bolts the way they are worse case i get another head gasket for $20 but i don't want to ruin the block with the diverters. If anyone knows the wright location for them i would appreciate the help thanks.
