WINDJAMMER
Thread starter- Joined
- Nov 25, 2002
- 16
my 91 force 70 hp has no compression in the middle cylinder. the foam on the inside of the cowl has been dry-rotting and falling off motor was missing the carb. cover when i bought it so it probably has been sucking up pieces of foam.. i was running the boat and it made a noise and stopped. started right back up and got me home, had rough idle. just did compression check, motor was stone cold #1 =120 #2 = 0 #3 125. # 2 piston is moving up and down in the cylinder and can't see any damage from the sparkplug hole. looking for direction on what to do first-pull and check reeds or pull head and look at cylinders
