No accesories
Dreamland
2002 Polar 1910 center console with 140 hp Suzuki 4 stroke
just had boat serviced and now
Suzuki has power will turn over and run
accessory switches all light up
but 0 accessories will come on no navigation lights, no bilge, no live well pump, nothing ?????
Help
is there power at each switch? are all the grounds connected? what does your voltage checks tell you?
Since the switch pilot lights illuminate, that indicates there is power at the panel. There are two ways to troubleshoot each circuit. Don't try to fix everything in one shot. Pick one circuit, turn the switch on and start at the "load" side (output) of the switch and follow the juice with your voltmeter. When you lose power you found the problem. The other method is to start at the device and work backwards. Obviously check the bulbs and connections for circuits that include lights. Mast mounted lights tend to have the sockets go wonky,.
