chitownborn
Thread starter- Joined
- Jul 13, 2007
- 178
hello, first time poster, long time reader, my problem is the third cylinder is flooding with gas 87 force 85 hp model no 856x7b, ok just a little history, i discovered the motor was running on two cylinders, come to find out bad trigger wire was broken at the base for the third cylinder, i replaced the trigger and while i was at it i also rebuilt the fuel pump, changed the check valve in it , rebuilt carbs floats parrel to base while inverted, new puddle drain gaskets and screens, check valves check out ok. it runs beautiful on two cylinders,just a tap of the key and fires right up,idles perfect, throttles up just fine. after ungrounding the third cylinder spark plug wire and putting it back on the plug all kind of issues start going on. starter has a really difficult time turning, binds and will not start. while third plug wire hooked up, i pulled the puddle drain hose off while cranking at the base of the drain and i get fuel coming out of the bottom port that the hose connects to, i go back to grounding the plug wire, get two squirts of fuel and were back running on two really nicely. got good spark on all three, at idling hits at tdc, static timing at 28, good vacum on recirculating system, reeds are fine, primer bulb when pumped stays hard, good fuel, idle mixture screws set at a little over three quarters, anyone have any ideas on what to look for, thanks in advance don
