NMEA 2000 Suzuki and Lowarance 334c Can I get engine info?
v12mac
If I connect a Lowrance 335c GPS to a 2007 Suzuki 225 will it display engine info or will it only push GPS info in to a NMEA network IE I will still need the SIMS gages?
This boat only has the standard gages on it now and I have seen folks hook up newer high end GPS systems and get all the eng (RPM Fuel burn ect)
My question is will the 335c show NMEA 2000 engine info?
k4ubr
Re: NMEA 2000 Suzuki and Lowarance 334c Can I get engine info?
is the gps nmea 2000 campatable,
v12mac
Yes it is NMEA 2000 compatible it runs the LGC 2000 GPS ?puck? however the question is can this unit display NMEA 2000 Suzuki engine data.
Perhaps I should have posted this under electronics.
