Will make no difference if set at 0 or -3 deg as carb is still working on ralenti/idle, roller is not touching cam at extreme right end portion.
Happy Boating
Actually I took it out at 0 deg and the idle is way too high, had to dial it back to -2 deg to get it off the roller. If you check the pic the roller is acting on the cam @ 0 deg.
Don't know why you like continuing messing with the whole engine if you haven't swapped 15 cam, right ?
Happy Boating
Forgot to mention that idle rpm must be slight decreased with carb's idle screw to lower engine's revs to a point that when lever is in forward gear while pushing combo engine doesn't die from low idle rpm.
Once cam is swapped probably will need to perform a new timing plate/carb sync.
- Throttle fully the grip, check if achieving carb's butterfly full stop at 180 deg, If not post a pic of carb's linkage to check that out.
Happy Boating
