Nissan nsf15 c1 manual
natanz123
I have Nissan NSF15 C1 ,2010 outboard and am looking to buy a good manual .Could you recommend one? And where to get it?
Natan, Mississauga, ON, Canada
pvanv
Re: Nissan nsf15 c1 manual
Any Nissan/Tohatsu dealer (including myself) can sell you a Factory service manual for the NSF15C. Don't bother with an aftermarket manual. See http://www.nissanmarine.com/search/index.html for the dealer locator
The Nissan Marine manual is part number 003N210620 SERVICE MANUAL NSF9.9/15/20C $26.52
Note: for service of power tilt/trim (PTT) models, see service manual #003N21062-1 (supplement containing PTT service data of 9.9/15/20C models), $17.33
natanz123
Thanks, Paul,I am going to have an extra prop: 3BAB645180 ( pitch 10'')
and manual 003N210620. Is it available to get it from your warehouse?
Could you give prices and shipping cost to 3665 Arista Way, Mississauga, ON, L5A 4A3. May I have your Website or e-mail address or contact tel # ?
Have a great day, Natan
pvanv
You can call me at the office: 716-877-8221.
You will want 3BAB645180 PROPELLER (8) 3 X 9.25 X 9 (F15C/20C) $117.88. I get parts from Texas in about 2 days, so just let me know when you want it.
pvanv
The 3-blade should be OK for a spare. the 4-blade may not be a good match, depending on the overall rig. Give me a call and I'll check what I have in stock -- since it's only for a spare.
pvanv
Natan,
Your manual will be on the way.
For correct prop selection, a tachometer would be helpful. Maybe you could borrow one for testing. For your 600-pound rig, you may be able to use the 4-blade prop, but you will probably lose some low-end hole shot, because the 4 blades act like a steeper pitched 3-blade. The ideal prop allows the motor to come up to proper WOT RPM without going over it. The prop selector chart at http://www.tohatsu.com/accessories/prop.html shows that you probably would run a 10-pitch 3-blade prop, but every boat is different, and pitch selection is always a bit of a trial-and-error process.
If you are hitting the correct WOT RPM now with a 9 or 10 pitch 3-blade prop, the same pitch in a 4-blade will be too much, and will kill your hole shot. But you need to know what RPM you have now in order to correctly select a spare prop.
You can always post your prop question in the propeller forum to see what the prop guys think.
