I have a NS70A nissan that will not idle .It stalls every time I stop and put the shifter into neutral.It will run if I put it it start up by moving the shift lever forward out of gear.It also spitters at slow speeds or when I am trolling .Can air leakage from bad fuel lines or lines on the carbs cause this?.
Could this be electrical I noticed that at 3000 rmp I was charging 14-15 volts?
