Nissan 55 HP Fuel System
Harritwo
Does anyone know a solution or a source for parts for the plastic fuel fittings and vacuum fittings for the Nissan 55? The fittings are either cracked or missing and i need to eliminate the vacuum leaks to make this engine run right. Ideas or suggestions, parts are greatly appreciated?
Paul,
I will be headed back in June to work on this some more and I am trying to gather the needed supplies now. If you have anything, let me know.
George
pvanv
Re: Nissan 55 HP Fuel System
George,
Some of the crankcase nipples are probably still available. The fittings for the carb inlets never were available separately -- so you either need a different carb, or you would have to make something up yourself for those. If you can get me the specific items you need and drop me an email at paul@obersheimersails.com, I may be able to help you.
