Nissan 2004 nsf 18B2 idles but wont run
paggy
I have a Nissan 18hp that will idle but will not speed up. plugs look clean. Fuel filter looks ok. any suggestions on trouble shooting will be appreciated.
Sea Rider
Re: Nissan 2004 nsf 18B2 idles but wont run
Welcome to Iboats forums,
Is that a 2 strokes engine ? what is "will not speed up", kind of misses, bogs down, more precisely symptons would be required...
Happy Boating
paggy
Happy Boating
4 stroke , will not speed up under load, bogs down
pvanv
That's a 2-cyl carb 4-stroke with ABS and accelerator pump.
Grab a Factory service manual, and using it as a guide, diagnose the problem. Likely need to clean the carb, but could be any number of problems. Don't guess -- diagnose. Verify oil is not over full, then... Start with the fuel system, and if NTF (no trouble found), continue to the ignition and mechanical systems, in that order.
If the motor seems lean (sounds like it), the most common situation is varnishing in the carb due to not running the carb out at the end of each and every day. If so, you will need to remove the carb, completely disassemble it (even all jets and the emulsion tube "nozzle"), and do a 4-hour soak in real carb cleaner, followed by a liberal blow-out of all passages with generic carb spray... then a careful reassembly, paying particular attention to float height.
