MVFD-430HD
Thread starter- Joined
- Jul 26, 2010
- 2
Hi!
Noobie here! I did search but did not find anything quite like my oil issue...
1. I have a 430HD inflatable and with the flatbed trailer I have, I need to remove the motor when I trailer. I have a Dolphin anti-cav late on it and after it is stored on it's side for a while, it leaks oil out of the water intake on the LUnit. Is there a problem or too much oil in the crank?
2. I would like to run a propguard on this unit. But I would need to run an 11 inch unit. They recommend running a larger diameter prop (up to 10.5 vs. 9.25). Can I used a turning point prop with the correct 14 spine hub kit?
3. The 18 and 20 HP nissains look to be the same displacement. I saw that the 25/30 conversion can be done. What would be needed for the upgrade? (the 430HD is rated to 40hp). I pull the kids on a tube and would like just that little more umph....
Thanks! I can split these if one takes on a life of it's own...:redface:
