nissan 18 horse compression
flydown
What should the compression be on a 2006 Nissan 18 hp outboard?
JB
Re: nissan 18 horse compression
Even to 15% difference. There is no psi spec. Too many variables.
Sea Rider
If it's a 2 stroke 18 HP, Cylinder Compression : 107 psi, must not exceed 15% between cylinders.
Happy Boating
pvanv
Compression specs are in the service manual for your model, along with the technique to obtain the numbers. You didn't mention a model, but if in North America, it's likely a 4-stroke... the NSF18, right? Keep in mind that gauges vary wildly, so as long as within 10% and not super low (say over 100 psi), you should be OK.
