jgibbs2037
- Jul 4, 2007
- 14
This has me stumped. Even when new, this outboard would sometimes sputter a bit til FULLY warmed up. Suddenly this years its much more prevalent.
Typical use case...
65F water, Air between 55 and 70.
Start the engine (starts right up and idles great.)
2 minutes or so while loading (still great)
3 minutes or so while idling out to the bay (great)
OPen it up, runs great at WOT.
About a mile later, it starts sputttering/popping, and I have to drop to 1/2 or less throttle.
About another mile later, it gradually starts running fine and I open it back up.
restarts are fine unless it sits a few hours, then it can repeat.
I have sprayed out the carb (not fully cleaned/dipped yet).
replaced the thermostat
Sprayed out and tested the enrichment solenoid.
Fuel Filter
Plugs
Fresh gas.
Squeezing the bulb does not help.
I plan to flush out the cooling circuit and replace the water pump and remove the carb for a full dip/rebuild.
But its always did this a little even when new. This fall it seems worse. I am tempted to try running no T-stat as a test, then trying one thats a higher temp. I run in Michigan, its not that hot here..
Any ideas on other things to check? I am stumped. It seems like its temperature/T-stat related. Like when the stat opens, its cooling too much, or maybe the stat is opening late and its too hot for a while. But like I said, i replaced it anyhow.
Thanks in advance for ideas!
Typical use case...
Fuel Filter
Plugs
Fresh gas.
