Re: NGK vs. Champion Plugs
Conventional plugs work best for all-around use. Surface gaps work better for sustained high speed. The QL16Vs have a small head which is supposed to foul less for long periods of idling, plus they work well for sustained high speed. But like you said, they're awfully expensive. I haven't run into a situation myself that they would be justified. They mostly are there if you have fouling problems with the more common offerings as a last-resort-try-this option. But I'm sure that shop has a higher profit margin than on the cheaper versions.
<br /><br />Generally I prefer ACs for GM motor Sterndrives, Autolites for Ford motor Sterndrives, Champion for American Made outboards, NGKs for Japaneese made outboards. Notice I say "made". A lot of Mercs are Yamahas with black paint. On those I'd use NGKs, as well as the Evinrudes made by Suzuki.
