Newbie with a 1979 75hp Stinger w/shift issues.
cosmic12
First, Hello and thank you all for the info I have gathered being a bit of a lurker here. Figured it was about time I joined.
I just got a 79 75hp 3cyl Stinger with a bad gear case, was told someone put the wrong (to small) prop on it and over wound it and blew out the gears, whatever the reason it was junk. I found another one that seems to be the same all looks correct. I pressure tested it all good. Installed a new pump and put it on the engine and now it won't shift into foreword. Net/rev fine. I am thinking (after searching here) the shift rod has been turned out of adjustment. Can someone please tell me the correct way to get it where it should be? I am very confused over the info I have found, this being the !st Johnson I have ever had or worked on. I do find most everything much easier to deal with than every Merc I have had and thats why I bought it but I have a learning curve ahead of me. Again confused about the rod adjustment and what it should be.
boobie
Shift rod height is 21 23/32 " in neutral. Measure from the top of housing to the center of the shift rod hole.
